UPDATE! Went to Fatman's on Sunday to fit the drive-shaft. Decided to do a write up after a member from the UK starlet forum told me he was doing the same thing and would need some help.
First things first, car was jacked up so the wheels could spin freely.
Managed to get a decent look at the old shaft, note the huge amount of fluid sprayed on the underside.
So took it out and laid it next to the new EP95 one.
A few things that were slightly different became apparent.
Firstly the mount points for the exhaust hanger thing are on opposite sides, not a huge deal as the factory exhaust is fine without it.
Old
New
Secondly the lengths are also slightly different, also not a problem as the mounts have room for the bolts to slide.
The major difference however is the flange on the transfer case side. The holes were out a few mm's
So after thinking about it for a while, we decided to see if we could swap the flanges around.
If you look carefully at the photo two back, you'll notice the special 'deformed' nut.
In order to get this off you need to either, stick a small flat screwdriver down the hole (hard), or grind some of the top corner where the hole is to make it bigger (what we did)
Then its just the simple step of putting the old flange on, which bolts straight on.
And putting it back in the car.
Big thanks to Fatman for helping with the install and pretty much figuring out how to make it work
Video of it running
