MODEL :starlet GT
YEAR :1991
ENGINE : 5E-FTE
Driveline:
5E-FHE block
5E-FHE cams
ACIS inlet mani changing at 5300rpm
Ross forged pistons
PAR forged rods
AGZE injectors>>>>>>>>>>>>>>>> now replaced with Denso BLUE 600cc Injectors
Steampipe exhaust mani with a GT2560R turbo>>>>>>>>now has GTX2863R turbo fitted
3" dump pipe ,>>>>>>>>>>>>>>>> 3" exhaust
V5 LEM link ecu>>>>>>>>Now has G4 storm ecu fitted
TRD LSD>>>>>>>>4.3 diff ratio and C56 gear set in C52 case
VR4 front mounted intercooler >>>>>>>>>>>>>>>replaced with 300 x 450 x 75 intercooler (new)
TRD pressure plate modded for more clamping (now 2060 lbs)
>>>>>>>>>>>>>>>>5 puck custom clutch plate
>>>>>>>>>>>>>>>>>60mm subby throttle body
>>>>>>>>>>>>>>>>>Baffled sump and Accusump fitted
Suspension
>>>>>>>>>>>>>>>>>Whiteline heavy duty front swaybar (24mm)
Whiteline anti lift kit
Whiteline rear swaybar
All bushes replaced with polyurathane
Tein Flex coilovers with camber plates
205/580/15 Khumo C03 semi slicks in the dry
195/50/15 Khumo 712 tyres in the wet
Brakes
Brake master cylinder brace
Hawk Plus race pads all round
Celica calipers on slotted 22mm thick rotors at front>>>>>>>> replaced with wilwood 4pots on 25mm discs at front
>>>>>>>>>>>AE92 rear discs on custom hubs with wilwood 2 pot calipers
Braided lines
High temp brake fluid
Interior
Welded in roll cage
Racetech seats with 6 point harness's
autometer gauges
Stripped interior
TRD 280km speedo
Exterior
bonnet pins
White body , green panels (no money left to paint it
Some stickers inc race number
ICE
the sound of the motor , prefrablly around 7500rpm
New turbo and G4 fitted
